packratt
Active Member
Took the truck on its first trip since the new motor was installed.
TD got a data set for the ATT going up the westbound side of Afton Mountain. Going up that grade south of Salem on 81 where the truck lane is was going to get another data set but had a right front tire decided it didn't want to stay in one piece about half way through the run. Had the pleasure of changing a tire on the side of the interstate in the rain at night with a bottle jack that was almost too short.
Pulled back into the house late Sun night and had oil running down the fender of the truck. Started cussing and immediately powered down. Popped the hood and everything had a coat of oil on it. Checked dipstick, no oil visible. Pulled a sample to send off for analysis. Drained oil pan and got about a quart. Filter is in 2wd configuration so it's full. Upon further examination leak appeared to be in oil cooler. Removed oil cooler and drained lines and blew oil out of cooler. After doing this had a total of about 3 quarts of oil remaining in the motor at time of shut down. Never had a drop in oil pressure.
Pressure tested cooler and found a leak between the plates.
Since I still had some oil and never lost pressure I should be in good shape. Anxiously awaiting results of oil analysis as confirmation.
