Hey I'm new to the form so if I post in the wrong place I apologize. I recently purchased a 92 hd with a 599 block . I was told that it was parked do to a fuel issue ( found out it was the ops). It had Sat for years and had rust in the cylinders so wouldn't turn over a complete revolution. Tore it down did an overhaul,rods, mains, cam bearings, hv oil pump . lifters and lifter bores looked good. Truck runs great now. My issue is that the oil pressure starts out at 65-70 psi at cold idle and drops to 15 once warm. Pressure verified with high quality gauge teed into sending unit fitting. Oil clearance is .0025 on rods and mains ,checked every journal with mic and bore gauge twice. Oil galley plugs are installed and oil bypass valves under the filter were not removed . I even used a hydraulic hose to jump my cooler ports to eliminate a possible plugged cooler. Running 15/40 rotella and wix filter . I'm out of ideas , I'm new to 6.5s but build a lot of 4 and 6cyl diesels for equipment. Is there some plugs that could have been missing before I got to this or a bolt or passage that might need sealed ? I know these engines have low pressure at idle but over 50 psi drop and only 5 psi at the turbo at hot idle doesn't seem right. Any suggestions would be appreciated.
