M123KT-450
- Messages
- 442
- Reaction score
- 0
Thank you very much you have been most helpful. . .
Mikey
Mikey
How much lube dose each axle hold ?
dose the rear need the the additive ?
Mikey
Well first off thanks for the info ! On the lube...
Second of all the 4.56s extra 271rpm will be plenty I think considering right now 65 = 3000rpm in third gear so now it'll be reving 3271rpm at 65mph !
How much higher you want me to run it ?
My transmission Guy Dose not recommend towing in 4th gear until i do some of the folowing cooling system upgrades.
1. HD trans cooler. i am to swap my 11x6x2 cooler for the 13x7-3/4x2 cooler.
2. Get the Cooling Transmission pan.
3. Upgrade to synthetic AFT and high end filter.
He is the one who suggested the lower gearing as it would make the truck run free, he then went on to explain that by running free he ment make the truck easier for the transmission and engine to move. he then in turn said this will now make any power adders more effective as less power will going to the operation the truck leave more power in surplus for carrying extra load or simply moving empty truck quicker.
Mikey
Yea well i ain't telling you to do it to your truck. . .
Mike
