RNation
I am looking for a new proportioning valve but am having troubles finding one. No one in my area carries one. I wanted to replace mine to be able to rule that out for a break issue I'm having. I've already replaced master cylinder, pads, drum pads (not sure what their called), wheel cylinders, and even a brake line. The back passenger bleed valve doesn't have the same amount of fluid coming out of it when bleeding like the other ones do (it has new wheel cylinder and brake line from the "T" in the back).
Anyhow I think if I can replace the proportioning valve, either the problem should be fixed or that's 1 more part to rule out. Plus I've replaced so many parts on this truck, I kind of like putting new parts on here as I go.
Thanks in advance.
Thanks in advance.
