M123KT-450
- Messages
- 442
- Reaction score
- 0
My truck on the level Runs 2400rpm locked in 4th at 70mph. . .
I was hopping to achieve by going from the 4.10s to the 4.56s was to get some place in between my current 4th and 3rd gears. truck should still run 65mph in 4th gear with 4.56s its only really going to run the engine about 250 rpm more at the same speed so 70mph@2650Rpm. . . yea the R's are still up there but i have already ran it 100miles each way steadly Run 3,000Rpm and it only ran 10 degrees hotter, water temp stablized at 197*F Reving 3k. . .I only make this run 1 to 3 time a year so it ain't like it reved up every day most of the time i drive truck it dosen't seen more then 58-62mph. . .it spends 85% of it road time in town. . .
Plus nothing saying i can't drive a little slower. . .
What i didn't want to do is chip it up and mod the heck out the motor and now i have this kick but 350hp 580tq 6.5L power house that keeps smokin trannys. . .
I was trying to achieve same effect but building it from the other end. . .
Drop the gearing to the next set lower put RV/HD towing shift kit in the trans run Super HD cooler devices then slowly open up the motor do the box n exhaust then if it needed more do the wast gate then on to the chip. . .
Mike
Mike
