I ordered two pair of the Phillips HIR1 9011...since both hi and low on the denali housing is 9005's... should be here Wednesday
will use Ferman's link to trim them...
Note: IIRC FErman said Wagner makes a 9011...but from all the reading I've done is, it won't be a true HIR bulb... Phillips owns the technology for the bulb...even though I read that Phillips actually changed the technology some since owning it, and the basic operation of it is no longer the same with the reflection heating the element further for a brighter light being changed (maybe even eliminated if I read correctly) they only original HIR's if you can find them have a globe shaped bulb...
I'm no electrician, but I think I may have a bad relay on the KD harness or something...I know there was some other reason I quit using it besides switching to HID's...of course it may be a 6.5 guy fix...Grounds grounds grounds...
I may just order another kit...this time the painless kit...or if anyone knows of a better kit...heavier gauge wiring etc...let me know...
I also want to do the foglight mod(no clue), as those are HID and still work great...so when I use my brights I don't hot strike the fogs...
