SmithvilleD
Active Member
Walbro's "life" spec at >18,000 hrs seems a long run-time if it's realistic.
Seeing that you've been successfully running the 10 micron filter pre-lift pump for some time, I picked one up which I'll swap in place of my current 30 micron. If the additional fuel volume per solenoid stroke is the cause of the increased pulsation, it could be the added restriction will rein in the Walbro some.
