Nessmuk
Back when I had the engine out I painted everything. Apparently the paint on the metal timing cover on the pump side came loose and the coolant found its way under the gasket. The side to the oil was perfect as was the outer side everywhere the coolant doesn't touch. Where the coolant did come in contact with the paint, it came off like it had oil under it.
Glad I'm running a bypass filter. But it's a pia doing the gasket while sweat runs onto your glasses lenses. Everytime I think I've got it all tight and good to go...
