schiker
I think I have my fuel leak fixed. No fresh accumulation that I can see in the engine valley using a flashlight. I degreased my engine and used some non chlorinated brake cleaner to clean a bit around the FSOS and inlet and its still clean and dry. I had a lot of mixed water simple green and oily residue at first then I poured some acetone into the valley using a long funnel so it wouldn't pour over other stuff and that evaporated the fuel, degreaser, water, oil etc.
I probably had some seepage from fuel manager ORing but most probably was coming from hose on IP inlet. Especially after I replaced the Oring and probably pulled some on the inlet hose reinstalling the fuel manager. My truck runs a bit better now and bet it was sucking some air at times plus new filter. I have a fuel pressure guage and the factory LP can drop to dang near zero psi sometimes. I want to upgrade the LP sometime soon.
