BigDogYJ
Its been over a year since I've been on the forums (too much going on).
But I'm stuck... (careful its long).
I was getting on the highway 2 days ago (light-med acceleration, unloaded just me in the truck). Got to 45 mph and lost all power (engine power). Electrical was fine. but no amount of throttle input did anything. coasted to a turnout and as I came to a stop it stuttered once and died.
I could not get it to start back up (just crank - no start). primped the filter till fuel came out of the bleeder, pumped some more, still crank - no start.
Changed Fuel filter, primed again same as before. Still crank no start. Get towed off the fwy. Got it started last night after just continually cranking. finally started stuttering to life. it idles now, but had a irregular miss every so often (feels violent).
I got EFIlive connected to read some PID's commanded fuel pressure seems to match actual fuel pressure at idle. if i use efi live to increase rpm, i cant get it above 1500 rpm, it starts loping between 1400-1500 pretty bad, and stuttering and popping every so often. sometimes get a puff of black smoke.
If I use the throttle pedal, it increases past 1500, up to 2500 but still runs rough and pops also.
only code was when it first died (P0087 - low rail pressure). Fuel tank is full, fresh filter, ran fine for 2 hours on and off throughout the day, then just died.
Any help appreciated. need to get back home this weekend and right now it aint gonna make it the 3 hour trip home.
Let me know any ideas or if you need any other info. I have efi live, ppe, code reader, i can take video, pictures. anything. let me know. Thanks guys!
