Diesel Tech
Registered User
- Messages
- 98
- Reaction score
- 0
The simple fact is that the factory down pipe and factory up pipes were design to give a certain amount of clearance and be manufactures quick and easy. Opening the downpipe on a Duramax works plain and simple. Now as for how much it worth to anyone you would need to price all the parts that your getting. If you replace the downpipe ONLY so that it ties into the stock exhaust you are limited by the Vband clamp that connects them. With that said the ID of this connection is ~2.5". That combined with the factory design pipe that has the pipe narrowing down to ~1" causes higher drive pressure and heat. That is just why I stated before that in order to use the MATH YOU HAVE TO USE IT PROPERLY! For the record the VE of a Duramax at 30 psi boost is ~132%. Real measured numbers in an engine dyno cell. IF you leave out the problems that the factory pipe has the math is going to give you the wrong answer, as it should. I can tell you that if you TEST a stock exhaust with no muffler you will be able to measure ~ 5psi of back pressure in it with a stock turbocharger and stock tuning. Again a fact, because it was measured! Then going to a 4" from the downpipe back dropped that to ~ 3 psi. Replace the downpipe with a TTS kit and a 4" exhaust and the measured pressure was <1 psi. The test point was drilled and tapped into the exit of the turbocharger so it never had to be removed during any of the test.
Then start adding power to over and above stock and all the numbers begin to rise in stock trim where as the TTS system stays about the same up to ~ 550 RwHp. Now as for the TTS kit your getting the front pipe as well so that is an added cost but what good would it be to supply the downpipe and not be able to have the customer hook it up? What good would it be to supply a downpipe then close it down to ~2.5"? Go price a downpipe and then add to it the cost of the 4" front pipe that you can buy today and see what that cost. Then understand by doing that you still have the factory Vband clamp connection at ~ 2.5".
