Michaeljp86
EVIL GENIUS
if the pulley is bad you should be able to rotate it back and forth
Would I have to take the belt off to do that?
Look at this picture and enlarge it... http://www.autozone.com/autozone/pa.../_/N-j92mbZ93y2h?itemIdentifier=72833_0_8644_ There are 3 pictures there so if you look at the third, the one which look like pictured from front of engine you see like a metal "cross" with four holes in sides for bolts. In my case the inner part off rubber was cracked all around and the bolts which you see their holes pictured equal distanced from the "cross" were touching the "cross". As result I got that "knocking" noise. It is possible that you don't have this type off pulley but if you have it it, is worth checking.
