Sorry for the delay guys and gals. I'll try to answer the questions / coments as they came in this morning.
We'll try to get a video up sometime tomorrow.
As for the heat shield, not it he currently has it removed.
He has not heard the motor run prior to installing in this vehicle. Very well could be the reason it was sold.
Engine doesn't miss.
The lines have been off the engine as they were taken from the origional motor that was removed. (don't believe he removed the lines from the IP, just disconnected from the injectors and transfered it to the new motor)
No smoke, not while driving nor at startup.
A youtube video of this noise would be very valuable. Good luck to you.
My internet guess is...heat shield loose between the turbo and valve cover.
Did you hear the motor run before it was purchased?
It may be the reason it was sold is because it was knocking
Does the engine miss too??
These things should purge air in short order.
Did you have the injector lines off the engine??
If so there exists the possibility that a couple are mixed up at the IP. This will cause lots of smoke and noises.
Let us know.
MGW
