First post here, hopefully a good one. I've been reading for the last week or two. Think its time I reach out for help.
I'm really posting on my buddy Travis behalf. He recently purchased a 1996 C3500 with a bad motor. Travis acquired a new to him used motor. (actually his third used motor other two had bad cranks) With the little bit of help I gave him he got it running after bolting everything back up.
On to the night her first started it up. Travis filled the fluids, purged the injectors and she fired up after the batteries spent an hour or two on the charger. Motor idled fine, let it idle for about a minute, give it a small rev or two. Motor knocked just a bit while letting off the gas, not at idle. We noticed a bit of a oil leak from the external cooler clip deals. (looked to be less than a quart) Shut her down for the night. Total run time no more than 2 minutes.
Next day he corrected the oil leak issue. Fired her back up, knocks now at all rpms. Few DTC set (didn't note #'s, details noted below). We're not sure where to start... Cylindar balance DTC on 7 & 8, replaced injectors on 7 & 8 (had a few new in the box). Same knock.
I've filled out the 6.5 Engine Diag. Troubleshooting Checklist to the best of our knowledge.
Any help would be greatly appreciated!!
Tks,
Matt
Year: 1996
- Truck model and class (ie: c2500) c3500
- Automatic or Standard _Automatic
- Mileage: (indicate miles or km) 230,000 Miles
- Replaced parts and mods (IP, PMD, chip/PCM, TM, injectors etc) Replaced motor w/ 605 block from Military Humve______
- Model: ‘S’ or ‘F’ engine, NA or Turbo, EGR? __Turbo Engine______
- Ambient outside temp: (indicate *C or *F) ___80*F
- What fuel are you using? (#1 Diesel, #2 Diesel, Bio, VO, WVO, etc)
Good Question... Fuel (presumably diesel ) remaining from previous owner / Unknown age
- What fuel additives are you using? _Unknown_____
- Where are you located? __Pea Ridge, AR_____
- Air filter _Looks to be new__
- Fuel filter _Unknown_____
- CDR Valve? _Unknown____
- Coolant – last flushed/replaced at _New________
- Oil – synthetic/regular, changed at _Regular New______
- Batteries – state of charge, (matched set) replaced at __good charge_____
- Battery cables and grounds (removed, cleaned and tightened): _cleaned and tigtened________
- Glow Plugs - how many miles on them? _Unknown_______ What type? __Unknown_________
- Injectors - last changed at _______________
- What were you doing when it happened? _Standing around _:smile5:____________
- How was the truck running fine before this problem appeared? _____________
- Has this problem ever happened before? _______________________
- Describe any related factors that might be part of the problem. ______________
- Have you checked for DTC (Diagnostic Trouble Codes)? (Y.N) _Y__ And? (didn't write down DTC) something about Cyl 7 & 8 Balance System, Map sensor DTC (replaced)
Diagnostics:
1] Starting:
1a] Does the engine start? Yes
1b] Does the engine crank over? Yes
1c] Are your batteries fully charged? Yes
1d] Have you removed, cleaned, and tightened all battery connections? Yes
1e] Does your Wait to Start light come on for a time? How long? _5-10 seconds
1f] Does your glow plug light come on? __No_____ For how long? _________
1g] Do you see smoke from the exhaust while cranking? What color? No Smoke___
2] Fuel Issues (if not running): Truck running
2a] Can you hear your lift pump working? ____________
2b] Do you get a steady flow of fuel from the water drain (T-handle) ? _________
2c] Loosen the inlet line from the IP – is fuel coming out (Lift Pump on)? ___________
2d] Loosen an injector line and crank the engine - does fuel come out? _________
2e] Do you hear a vacuum (hiss) when you remove the fuel cap? ___________
3] PMD / IP Issues
3a] Location of PMD (on pump, on intake, remote mounted) mounted on side of injector pump___
3b] Condition of Extension harness (if used) Vendor or Homemade? _________
3c] Condition of grounds / ground wires to IP / PMD. Check Harness. Look to be good___
3d] PMD Make: Unknown_
3e] PMD Age: _Unknown_
4] Stalling Issues
4a] Do you experience stalling only when hot? _No Stalling_____
4b] Does it stall under particular circumstances? (ie hit bump, or on accel) ______
4c] Does pouring cool water over the IP seem to help with restarting? _________
4d] Is stalling momentary (engine recovers)? _________
4e] Does SES light come on when engine hiccups? _________
4f] Does cruise control quit working when engine hiccups? ___________
4g] Does re-starting seem to reset engine, restoring cruise and power? _________
4h] Changes to dash lights or instruments during stalling events? ___________
5] Running Issues
5a] On cold start, does upper rad hose get hard before engine warms up? _Unknown______
5b] Any bubbles or oil film in coolant overflow tank? _Unknown___
5c] Any white slime on oil surfaces (dipstick, CDR, oil Fill cap)? __No_____
5d] Excessive white smoke from exhaust on cold start? _No______
5e] Excessive black smoke from exhaust under hard acceleration? _No_______
6] Performance Issues
6a] Do you have gauges? __Factory____
6b] Maximum boost under load? _Unknown_______
6c] Have you added a performance PCM (reflash) or Chip? _Unknown_______
6d] Have you changed exhaust / downpipe / crossover? ___No___________
6e] Wastegate – mechanical or vacuum? __Unknown_______
7] Temperature-related Issues: No
7a] Single or dual thermostats? ___Dual______
7b] Have you replaced them lately? Manufacturer of replacements? __No_____
7c] Have you pulled and cleaned Radiator and coolers lately? __No________
7d] Have you replaced the fan clutch? Manufacturer of replacement? __No_____
7e] (winter) Have you tested your antifreeze? Good to what temp? __New______
7f] (winter) Are you using a winter grille cover? ___________
Tks,
Matt
Year: 1996
Diagnostics:
1] Starting:
3] PMD / IP Issues
4] Stalling Issues
5] Running Issues
