Scottsdale 83
- Messages
- 32
- Reaction score
- 56
Is this constant pressure valve body something that you could get at an auto parts store?
I may end up needing one if I've damaged mine. Who are you talking about?If you ever need a 700r4 these guys do a great job
Thank you. Awesome to be here amongst true Chevy scholars..Welcome to The Truck Stop, Scottsdale 83.
Okay,I thought that was who you were talking about but didn't know you could just buy one from them like that. I'm very Leary of this type trans.i like the overdrive feature but if I could afford a new one I might go back with a 350 or 400 turbo. Everyone I've talked to about it talks like it's basically delicate. I've only driven it twice but I fear I've already done damage to it.Bowtie overdrive. The article is from they're website
The valve body is inside the transmission pan and the constant pressure unit is costly then there are two (2) different styles depending on the transmission build date. FYI "It will not correct anything on a damaged transmission."Does this constant pressure valve body attach to the inside or outside of the transmission?really sounds like something I should look into. I attached the cable in the proper spot and even with the throttle completely closed I still lack about two inches reaching the hookup on the throttle. I've had more Chevys than I can count over the years and have never encountered or heard of this problem.what I wouldn't give to have a good ole 350 turbo or powerglide right now.lol
But you still need a TV cable or vacuum modulator for it to shift correctly(so e way to alter shift vs governor pressure). I'm not a fan of constant pressure mods myself. It gives you max line pressure all the time. It's fine for a performance/limited use application, but asking for trouble imo for a daily driver. Not to mention as line pressure goes up, cooler flow goes down as cooler flow is largely the fluid the pressure reg dumps.The valve body is inside the transmission pan and the constant pressure unit is costly then there are two (2) different styles depending on the transmission build date. FYI "It will not correct anything on a damaged transmission."
The constant pressure unit eliminates the common throttle valve (TV) cable related failures.........
Great info as always FERM thanks..........Cooler flow is largely what is dumped from the main pressure regulator. There's no way to increase it without going to a higher volume pump or reducing pressure. When you increase the main pressure past a certain point, cooler flow will be reduced to reach the desired pressure. I know many are not fans, but electronically controlled transmissions are about the only way to have full control of pressure for durability, but still reduce it to maintain cooler flow.
That might be the wrong bracket that the cable clamps into, that clamp might be for an older trans, TH350 or some such. Check at the auto salvage and see if there is a difference. Some brackets have a hole for the cruise control and right next to it, on the same bracket is the other opening for the TV cable. It attaches to the left side of the carb, drivers side. one position on the throttle arm will be for the TV cable and the other nub will be for the cruise control, if it has the stock carb on it.Does this constant pressure valve body attach to the inside or outside of the transmission?really sounds like something I should look into. I attached the cable in the proper spot and even with the throttle completely closed I still lack about two inches reaching the hookup on the throttle. I've had more Chevys than I can count over the years and have never encountered or heard of this problem.what I wouldn't give to have a good ole 350 turbo or powerglide right now.lol
Cruise control connects next to the accelerator cable as they both pull. The TV cable is pulled, so it connects 180 out from the accelerator cable on the bottom, or it connects directly opposite of the accelerator cable.That might be the wrong bracket that the cable clamps into, that clamp might be for an older trans, TH350 or some such. Check at the auto salvage and see if there is a difference. Some brackets have a hole for the cruise control and right next to it, on the same bracket is the other opening for the TV cable. It attaches to the left side of the carb, drivers side. one position on the throttle arm will be for the TV cable and the other nub will be for the cruise control, if it has the stock carb on it.
My cable is about 3 inches too short.can I extend it with another piece of cable or will that affect the shifting or transmission?But you still need a TV cable or vacuum modulator for it to shift correctly(so e way to alter shift vs governor pressure). I'm not a fan of constant pressure mods myself. It gives you max line pressure all the time. It's fine for a performance/limited use application, but asking for trouble imo for a daily driver. Not to mention as line pressure goes up, cooler flow goes down as cooler flow is largely the fluid the pressure reg dumps.
By saying it sounds like it's done you mean it's toast? It's still going through the gears and I've not been driving it. I drove it home from where I bought it and maybe 15-20 miles testing it after working on it. I was saying I may need a new one in earlier posts as a worse case scenario.do you think it's still going to go completely out?Check to make sure the cable is routed correctly. Sounds like you have a v6 cable on a v8. New cables are not that expensive or hard to change. Problem is it sounds like your trans is already done, so hooking it up will not fix it at this point. Just one drive with the cable unhooked can fry a 700r4. It's the 1 thing you CANNOT mess around with. Misadjusted tv cables have messed up more 700r4's than anything else.
