was at the jy, looked for A/C hose to fix mine which i found. looked for a tcm, no luck there. got some intake hose from a, *cough*, ford, will see if i can make it work. found a dome light from a sub. matches the console. the part was $10.00. here is how i recovered it to match my headliner, that i put in, using the same material. took about an hour to do, 24 hours to dry.
this is what it looks like from the factory:
back side:
notice there is a diff in depth from the front/back side:
this is what is in there now. there are LED's in it but it looks dated i think:
these 6 melted tips need to be melted off, i used a soldering iron:
separate the frame from the inner part:
here's the material used, same that i used on the headliner and overhead console. bought from walmart:
adhesive:
cement:
cut a piece to stretch around the frame:
spray contact on frame, let it get tacky:
start stretching and cement the inside edges that will be hidden:
trim a little closer and clamp down:
when adhesive is tacky(moisten finger when pressing down to prevent it from sticking), cut out center section making relief cuts on inside corners, place adhesive to edge, keep the 6 tips free of material so they can get glued down. they don't have enough plastic to remelt closed for a good seal:
cement the edges......
but stay away from here, the lens cover needs to be free to replace bulb:
place clamps on edges to hold it together until adhesive sets:
before:
after:
![DSC01559.jpg](http://i110.photobucket.com/albums/n89/deejaaa/DSC01559.jpg)
back side:
![DSC01560.jpg](http://i110.photobucket.com/albums/n89/deejaaa/DSC01560.jpg)
![DSC01561.jpg](http://i110.photobucket.com/albums/n89/deejaaa/DSC01561.jpg)
![DSC01562.jpg](http://i110.photobucket.com/albums/n89/deejaaa/DSC01562.jpg)
![DSC01567.jpg](http://i110.photobucket.com/albums/n89/deejaaa/DSC01567.jpg)
![DSC01569.jpg](http://i110.photobucket.com/albums/n89/deejaaa/DSC01569.jpg)
![DSC01570.jpg](http://i110.photobucket.com/albums/n89/deejaaa/DSC01570.jpg)
![DSC01571.jpg](http://i110.photobucket.com/albums/n89/deejaaa/DSC01571.jpg)
adhesive:
![DSC01572.jpg](http://i110.photobucket.com/albums/n89/deejaaa/DSC01572.jpg)
cement:
![DSC01573.jpg](http://i110.photobucket.com/albums/n89/deejaaa/DSC01573.jpg)
![DSC01574.jpg](http://i110.photobucket.com/albums/n89/deejaaa/DSC01574.jpg)
![DSC01575.jpg](http://i110.photobucket.com/albums/n89/deejaaa/DSC01575.jpg)
![DSC01576.jpg](http://i110.photobucket.com/albums/n89/deejaaa/DSC01576.jpg)
![DSC01577.jpg](http://i110.photobucket.com/albums/n89/deejaaa/DSC01577.jpg)
![DSC01579.jpg](http://i110.photobucket.com/albums/n89/deejaaa/DSC01579.jpg)
![DSC01581.jpg](http://i110.photobucket.com/albums/n89/deejaaa/DSC01581.jpg)
![DSC01589.jpg](http://i110.photobucket.com/albums/n89/deejaaa/DSC01589.jpg)
![DSC01590.jpg](http://i110.photobucket.com/albums/n89/deejaaa/DSC01590.jpg)
![DSC01591.jpg](http://i110.photobucket.com/albums/n89/deejaaa/DSC01591.jpg)
![DSC01586.jpg](http://i110.photobucket.com/albums/n89/deejaaa/DSC01586.jpg)
before:
after:
![DSC01584.jpg](http://i110.photobucket.com/albums/n89/deejaaa/DSC01584.jpg)
![DSC01585.jpg](http://i110.photobucket.com/albums/n89/deejaaa/DSC01585.jpg)
