Bigfootedalien
2 Questions - 95TD GMC Sierra Xc 4x4 Vin S ::: When I jump A+B (OBD1) it starts with 1-3/1-3/1-3 the codes then 1-3/1-3/1-3 end ! WHY am I getting a 1-3 flash when it should be a 1-2 flash ? Should I be concerened! I Cleared all coded (pedals & retested DTCS & got again 1-3/1-3/1-3 then 6-2 x3 then back 1-3 x3! It cleared all codes & set code 62! Why 13 & not 12?
Question 2: I just sent my IP in for a rebuild (I was getting a DTC of 34 + No fuel @ the injectors) The rebuilder said the Poppet Valve was busted (DS4 pump - 5521) : Wheres the Poppet Valve lokated ? Why would that break / what would cause it to break (will i have a problem with my rebuilt pump?)
Thanks lar:thumbsup:
