Joined the #2 and #7 club
Golddigger
Northern Utah
My truck cut out while driving down I-15 this week. Sounded like a 4bt cummins:eek::shocked:. Pisses me off that GM doesn't fix any of their "KNOWN PROBLEMS!" But oh well it is fixed, officially out of warranty and will never see the dealer shop again as long as I own it.
Did you do the Ice pick fix? I have done it on my truck with gm's alleged fix and my dad's 05 with the stock connectors. Works like a charm. :D
I read them ahead of time but found GM's so called recall # so I was hoping :swordfight:they would fix their screw up. Not likely but I figured I'd try. To save myself high blood pressure I just had them fix it..... My GM bail-out.:D
I joined the club first at about 110K miles and then again at 135K miles. First one was number 7 second one was number 2. I did them both the first time but one worked its way loose again.
Good luck. I had to ice pick the "new and improved" ones within 2 months. Now it has been 18 months or so with no problems.
Noticed you're from northern utah. I live in Tremonton.
Still waiting for that special day. :rolleyes5:
Luckily it wasn't during my 1400 mile round trip this weekend. ):h
Mine happened the day before I was supposed to leave for a 1200 mile trip...i got lucky. but it took a week and a half to get my truck back from the stealer. i guess gm is out of the harness and wont have them back in stock till the end of the month. luckily got a set from another dealer
Yeah, you did get lucky. You can mod the stock ones though and usually it solves it for good. It's called the "ice pick" mod.
Yeah, just happeded to me on the side of I80 in nowhere iowa, only the #7 cylinder went, sounded like a really crappy powerstroke.
They only replaced the #7 cylinder connecter but gave me the connector for the #2 cylinder should i replace it now? and how hard is it to replace those connectors with the new 90 degree ones?
That sucks...I'm sure it will happen to me soon enough.
