Ratchetnator
Thanks I will do that for sure
I just put a kojo tow tune(bought used) in my 98,the tune was done for an ATT but i still got the GM8 turbo on it(with turbo master)
Stock inj set to 2300 psi,stock LP,FTB.
This thing hums man,lots of get go,no smoke.
People are saying the GM8 has turbo lag,wonder were that is, cause my boost is instantly to the max when i stomp on it and it stays there till i ease of on the go pedal.
What injectors do you run with the att? Stock our high performance? Heath says the hp injectors make high egt for towing. I wonder if that would be the case with the att and hp injectors?
That was my plan was ATT, heath HO injectors and possibly IC. Do you think I would get something extra from HO inj in this setup over stock inj? Are the Heath HO injectors marine injectors?
The HO injectors may be a problem if you are running the stock gmx turbo by itself, but with an inner-cooler you won't have a problem. gmc1999 ran his heath tune with marine injectors, inner-cooler, and stock gm8 towing a 10k trailer with no problems.
Another option that won't cause the marine injectors to cause high egt's is to swap the gmx turbo for the ATT and there won't be any issues with high egt's. If you experience high egt's with this setup then there are other problems.
I bought a Heath tune just before xmas $349:agreed:Obd1pcm, for '95 6.5td
heath 549
kennedy 350
wester 329 (+30hp) 429 (+60hp)
ssdiesel 299
3-banger 449 (ebay)
6-banger 599 (ebay)
kojo 359
Obd2 pcm, for '97 6.5td
heath 549 kennedy 575
wester 595
ssdiesel 599
kojo 359
as always, my suggestion is to support our vendors... kojo and heath have been here for us, and I have faith they will stand behind their products.
Do I need to plug up my old vac system or something? I threw a service engine soon light today and I have no idea why.
