Tookie
Put it on the scale a couple of days ago, weighed in at
5,940 pounds, with an almost full tank
Is yours a 1500?
You're all lightweights... Tookie, your truck must fly....
I come in right at about 7000 lb. Is yours a 6 lug or 8 lug 2500? If it's an 8 lugger, is it a full float rear or semi-float rear?
It would if they weren't counting full lbs. If they measured a pound at 90% of it's actual weight, they would save 10%.Mine's a C2500
Scale has you drive on, weigh, unload and reweigh.
So low wouldn't help them, but we have a scale
at the plant I work at, I'll recheck
Is yours a 1500?
Damn 6.5 must fly... I weigh mine in and out everyday, 9800average in, a little shy of 9200 out...
I remember it being 8700, then 88... then 89... I just keep adding more tools/boxes/bed modifications..
I have a metal bender (brake) permanatly mounted up top, and just got a new (used) 18x18x36 Diamond plate box to put on top of my other boxes... ($45 dollar score)... new they go $450+. Waited a long time to find a score for that.
I also store extra wood on the set of horizontal 'racks' i built.
