dbrannon79
I'm getting there!
as wered as it sounds. it sounded normal on the recording when i was out there. it wasn't knocking that I could hear. the only difference is I had just been out driving it picking my son up from school. I guess I need to video it when it's cold and see. trying to think what can knock when colder and not when fully warm, I'm not coming up with anything right off my headYou might pull the inner fender and turbo.
Crack the injection lines one at a time and see if the noise stops.
If it stops on one certain cylinder then swap around a couple of the injectors.
If the noise follows the injector then replace that injector.
If the noise stays on that cylinder then suspect a rod bearing is getting ready to let loose.
If the noise gets louder with the cracked injection line then suspect a wrist pin or piston is going to flap out on Yuh.
If it has been making noise for this long chances are whatever itiz, might just stay there for long time now.
