Is it safe to body lift a 6.5 powered truck?
Darkrider
Lobo Solitario
Lloydminster, SK Canada
Ok this was mostly spured on by conversations on gmt400 but I am wondering if it is safe to body lift one of our 6.5td trucks? I know the engine needs to be kept below 210 degrees. Does the radiator need to be kept in stock location or will an electric fan pull enough cfm to keep the engine cool? One other mod im considering is the HO water pump. So will the HO pump and an electric fan be enough?
Powered by Detroit Diesel
Some people say they have good luck with elect fans but I wouldn't do it. I also think body lifts look silly too but it can be done on a 6.5L, yes the bumper and grill will then be located wrong for maximum cooling.
To expand on the electric fan issue. IIRC (maybe someone can correct me if I'm wrong) the stock fan in my '98 moves somewhere between 10,000 and 12,000 CFM. The last time I checked, electric fans were nowhere near that.
Electric fans are good for cruising, but not seeing any supplier claim they dump enough heat when pulling hard (more specifically, there are disclaimers on weight limits for use with towing). There is one hybrid approach of an electric clutch fan mounted to either the stock or DMax fan, but this is pricey, needs a water pump with the spin-on versus bolt on attachment for the clutch, and a pusher fan out front to keep the A/C in check (unless you want to run the fan at 100% whenever the compressor is on).
also for the hyrbo-boost system for the brakes you would have to lenghten all the hoses theres not much extra lenght in them
So the general feeling im getting between what im reading here and reading on the diesel place its one of those things that will take a lot of extra time and money for very little gain and that it would be easier and cheaper to just go with a suspension lift. That about sum it up?
My 94 had a 3" body lift, when I bought it. both half's of the fan shroud were in the bed. I mod'd the top one to fit back in, and left the bottom out. I did have a HO h2o pump and duramax fan hd clutch.
the air intake tube was stretched a bit and the shifter linkage had a 3" spacer in it also. The kit came with new brackets for bumper alignment solutions. I towed 11,000lbs about 40 miles,, with NO issues.
No other mod's were required. If you want it,,, Do it!
heres a link to some pic's of mine when I bought it http://www.dieselplace.com/forum/vbpicgallery.php?do=big&p=29431
Hmmmm this def sounds encouraging. So basically if I mod the shroud and run the HO water pump with Dmax fan I can safely run a body lift...def worth some thought.
Just curious but how much of a lift are you looking for?
I have 1.5" aluminum lift blocks sitting in my garage collecting dust if you were looking for something like that. I used them on my Duramax before I lifted it.
