My fathers LMM is more responsive then my previous LBZ. His LMM has a tune also, but so did my LBZ.
REALLY?!
could it be the tune that makes it more touchy?
This is our new Suburban to a T. I hate taking off at busy intersections with ppl in it, because they either whine about how "hard" I'm hitting the throttle or how slow I went through the intersection. I need to get a tuner on there that removes the lag.Gas and diesel both suffer from this to some degree. Some have you slammed into the seat when the computer finally decides to open the throttle you are already 1/2 way to the floor.
The LMM stock is laggy due to the DPF programming insiude the ECM to reduce soot loading of the DPF. With a tune teh LMM runs just as strong as an LBZ does, and they are virtually lagless. I tuned one for somebody and it is just about brutal how instant the power is on a stock trans safe tune I built for it. You can take a bone stock LMM though and eliminate the DPF and make the changes in the ECM to shut off regen, DPF protection as well as kill the EGR and it will RUN STRONG!
All of these trucks in stock tune are plenty powerful but they do not have the instant throttle response of a gasser because they: 1) have to spool some and 2) because they are made to not throw a boatload of power into the trans all of a sudden.
There isn't a comparison to any gassers for the amount of power. That's why the DMaxes got the Allison. It handles the load and is NOT something to worry about. I had an 8.1 / Allison and since it was lower torque, it came on quick. The DMaxes, you ROLL into it. It takes a while to get used to it but it's second nature after a while.
The edge I have on my LBZ seems ok as far as throttle response. It does have some lag in certain situations that I am still getting used to though (compared to my 6.5s). Gotta wait for my tranny to "pick" a gear before fully mashing on it.
That's like how it is in my Truck with EFI now. If I'm on the Highway Cruising at about 60mph, and I put the Petal to the Floor, it's almost like (in this Order, but very Fast) the Engine Shuts Off, the Trans Downshifts, the Engine comes back On, and I take off.
It's def. not something I'm used to.
