IP timing OBD II
Well, I did the timing procedure. It really is kinda strange how the numbers "jump around" at any rate, it went from -2.20 to 1.63 after tons of KOKO's. It was at -1.94 for a while but then it reverted to the -1.63. Seeing as how I can't really say how I got it to -1.94 in the 1st place, I'll think I'll stick with the -1.63 for a while. I have plenty of other things that need attention on the rig.
Thanks to all who helped me out on this- I never could have done it without this forum!!
When it hit -1.94 I turned truck off like qwomack said to. When I started it up it still showed -1.94. After another shut down (without a TDCO learn) when I started it back up it was sitting at -1.63.
Not sure if that helps at all.
Oh- and I never moved the pump. It went that entire range without mechanical adjustment.
turning the truck off does not seem like a sound practice to end a timing procedure.
The same TDCO flucuation will happen after the TDCO relearn procedure in my OBD1 truck if I do a couple things. one is if I do not perform the timeset before each TDCO learn, and two is if I exit the TDCO learn procedure early myself. If I do the timeset or let TDCO run its course it never seems to flucuate afterwards. I have done it about 80 times on my truck.
