skhemer6.5
And the design of the fuel manager on the 6.5 scares the hell outta me knowing the past troubles I have had with the old box stanadyne on 6.2 circa 1980 s the hose barbs in bottom are same design as the stubs the filter pushed on to and thay worked loose and sucked air am I the only one to experience this a brass sleeve inserted into cast alum thats my main reason for wanting spin on I am truck mechinc I get dirty & oily every day fixing other people's junk why should I get nasty changing my fuel and any way u go to bleed air of u get diesel all down front of engine when u use water drain or the air bleeder the fuel stands in the valley of the engine soking ip harness in diesel who ever thought this up should be whipped with a hydraulic hose with one end tore off and wire stickin out one more thing how much trash do ya leave in the fuel manger if u dont take it out every time and clean it even the one on Leroys video how to change the screen is got brown gunk baked on the inside wall I goto rest a while need to put a water pump on b model cat in a.m. before I put my IP on my 6.5
Sent from my SAMSUNG-SGH-I437P using Tapatalk
