My truck is in the shop getting the injection pump replaced. The shop is not familiar with the 6.5L, but they are a good diesel shop.
I just wanted to clarify the procedure.
1. Remove existing pump.
2. Put new pump, tech scribed lines on both IP and body and made a template to mark new IP to line up where old pump was at.
3. Start truck, coolant to 170F + use TIMESET function (using snapon verus) to set timing at 0. (Desired timing/actual timing 3.5*)
4. Note TDCO.
5. Adjust pump to drivers side to make TDCO more negative value, pax side for more positive value.
6. TDCO set on snapon to get -1.94 TDCO
did I miss anything?
4. Note TDCO.
