buddy
Active Member
By this time the pump is likely the same, although there was a different pump used in 94 on most 3500s and HD models. It was model 5068. However if it went in for service GM typically replaced it with the 5067 or compatable model pump and changed the EPROM in the PCM to control it.
So chances are it is the same, and hopefully one that had been replaced since 2000 or so.
Besides the the nuts, you obviously also need to remove the fuel injection lines and the upper intake plenum.
