n8in8or
Thank you for your thoughts/experience Chevypoor. I'm going out to take some pics now and I'll post them in a little bit, but I've pretty much already relegated myself to needing new heads. It didn't push air into the cooling system, but it has used some coolant since I owned it. I always attributed that to head gaskets that were on their way out, but all things put together it seems I need to throw a different pair of heads on this thing. The one head I have cleaned up good has cracks in 3 cylinders for sure, and I'm guessing the other head isn't much better, so I'm guessing I'd have a bunch of machine work costs into a pair of heads that I'd always be questioning. I guess at this point I'm on a quest for a cheap pair of heads, knowing that I'll want to upgrade again in the future. I'm glad you guys with more experience weighed in before I went much further. On any of my gas engines I've worked on in the past those cracks would have been an immediate red flag, but I thought I had read people here running heads with cracks....I guess I was mistaken. I will forever now run under the assumption that any cracks in any heads is no bueno.
