Intercoolers: ATA,WTA and WMI What's Best?
it takes wastegate control away from the PCM/vacuum system and puts it on a mechanical spring loaded system, allowing you to adjust your PSI as desired, as well as providing more stable boost without the turbo "pulsing" that the stock vacuum system does to maintain PSI
