No the same length isn't as important, everything I have read as well as tuners says as stright as possible and as larger of plenum as possible, a near perfect plenum are is the same Liter as the motor from what I read for forced induction...
Our cousins down under love blown 6.5td's and make a point that is more DD friendly than any turbo.....If it wasn't for that damned IP, you could just bolt an 871 Roots blower to the heads, overdrive it 30% and be making boost at idle and be able to fuel the living crap out of it, too!
Then a BIG A_S CAC added to the menu will feed that hunger. I almost forgot twin screw is more efficient in operation and charge air temps too.I’ve delt with 3 of the supercharged 6.5s. 2 in hummers and one pickup. Did better than stock turbo, but not having coolers limit them in hot climates. Same power results as hx35.
If my old memory serves me right "no throttle plate makes it a different game because distance between throttle plate and intake valve becomes an unknown value."Happy Holidays to all,
I haven't posted in a while, some tubo-brothers on a forum kinda rubbed me the wrong way about a Eb@y find I shared.
Anywho, a fab'ed intake will certainly make more up-top hp but I fear you'll be sacrificing lowend tq in the tradeoff!
Strangely the 80's L98 TPI intake sys design might be a really good match to a 6.5's powerband?
@94DieselSub On boosted diesel engines the more “stored” pressurized air, the better the beginning fill rate of the cylinders. However longer travel time from the turbo adds to lag, which is where Chris’s concern of high flowing numbers helps by lessening the time it takes to get the air from turbo to piston.
