Resistance may not be so futile
The new Fuel Heater Element arrived today. Original Stanandyne part. With the multi-meter set in the 200 ohms range, it registered 2.0. Guess what Buddy...we're screwed
At least I am. You, living in the warmer climes of California, may not be in as pressing of a situation if it only activates at temps below 46 degrees.
Anyway, the part came with a new "O" ring, coil "spring" and 5' of additional wire with connector (male).:thumbsup: Those who wish to relocate the FFM could cut the truck side plug, splice in the new wire, and have room to spare. Or, leave the unit in it's original location and unwind the old wire from the loom and splice it in at the OEM locations. But, if relocating the FFM, there's the WIF sensor wires to deal with still. Figures.
Pictures to save a few thousand words.
Here's the old heater with the bare wire (which should be "Pink" oh by the way).
It's orange meaning the part was replaced with a non-oem part at one time or the pink got toasted! I better double check the inside of that wire loom.:agreed: Winter's coming and this thing is going to light up often I'm guessing.
Here's the new unit connected to the mult-meter.:thumbsup:
So, if you're checking your fuel heater as part of pre-winter PMCS (preventative maintanence, checks & services) and it reads "open" (Zero Ohms), I'm afraid you've got issues too.:mad2:
Just trying to help. :usa1:
