Instrument cluster confusion
Goose57
Eureka Mo.
Hi all I’m trying to get “Wait to Start” light working. According to my owners manual I shouldn’t even have a WTS light just a GP light. There are a couple of stickers on the cluster not sure what they mean. The WTS light was working before. I pulled the cluster and found a wire on the GP light twist socket going to the upshift light twist socket on the grd. side, because the copper trace was damaged, I did repair it.( see pic ). It was labeled upshift, but on the front side it said WTS, what the hell is going 💁on? ( see pic) and there was not even a bulb on the GP socket very confusing. I think they were using the GP socket for the damaged copper trace. I put a bulb in the socket marked GP and lit it and there isn’t even anything lit on the front side just blank. WTF. After repairing the copper traces ( I damaged the one in the middle ). 🤯 and getting the bulb to light on the WTS light ( marked upshift ) turn the key on to start the GP cycle and it blinked once and went out but still completed the cycle then started it and the now the WTS light stays on all the time. I thought for sure after fixing the damaged copper trace and getting the bulb to light during testing I was home free. I did hook up a test light to the WTS pin on the clusters connector in the truck and the test light stayed on during the cycle and after starting it went out like it should, but not when I plug the cluster in. I think I created a monster. I’m trying to find a used cluster and have it remanded but I’m now not sure which part number to get. GM Parts Giant says GM # 16197145 fits my truck but can’t find it. The one in my truck now is a 16176841, maybe it supersets it? I did find one on e bay for a 95’with no WTS light. Only year of OB1 on interior update what ever that means. Sorry boys for the long post. Thanks.IMG_1254.jpegIMG_1260.jpegIMG_1258.jpegIMG_1259.jpeg
Take a closer pic of how the wire is added between the upshift and the wts socket. also where you repaired the trace. is your's a manual trans or automatic? the wts light is the gp light. the wait to start should be lit when the GP's are running.
find the pin in the connector for the wts that you verified to work during the key on cycle and locate which trace on the cluster it connects to. then follow it to what bulb it goes to on the back of the cluster.
you can also shine a flashlight into the back of the cluster with the bulb removed to see if you have the right one. also you can remove the bulb and shine the flashlight or hold the cluster up to the sun looking in the hole from the back side seeing the wts from the inside. sometimes it's hard to tell but maybe your looking at the wrong bulb socket.
one thing you can also do is carefully remove all of the bulbs and shine a flashlight into each hole one by one seeing which light each one is for also will tell you if one lights up two indicators on the cluster. this was the case on my cluster as someone had been in mine before me and had taken some plastic out from inside modifying it. I ended up sourcing another cluster for parts to repair mine. I might actually have that cluster here for parts. if you need something from it.
if I still have it, I think it still had a good circuit on the back but I used some of the guts to repair mine. I think I used the inner plastic housing that sections off each indicator light and one of the gauges. the circuit is nothing more than a flexible ribbon with copper traces, they get very fragile with age.
IMG_1257.jpegThanks d, unfortunately I don’t have a pic of the wire that was added between the 2 sockets. The cluster is back in. I do have an Automatic trans. The red line I drew represents the wire that was soldered on top of the bulb twist socket. It even melted the plastic on the twist sockets. A real hack job. The soldered wire went between one side of the GP twist socket on the top, to one side of the Upshift twist socket which is the WTS light on the front side. U can barely see it in one of photos. I believe they did that to complete the circuit because the one side of the copper trace on the upshift socket cavity was missing. You can see where i repaired it, it isn’t pretty. The WTS light is working but not going through the cycle properly . I might of messed up the trace circuits trying to repair them, I’m not sure. I did put a test light on the WTS light ( in the upshift light cavity) pin on the cluster’s connector mounted in the dash and it is cycling properly but when I put the cluster back in it doesn’t. I believe some one was in there back in 98’ see pic they even wrote REV on one of the white stickers when they had the cluster out. There is even a wire missing on the cluster’s connector going to the top GP light cavity that should be working on my truck according to the owners manual. They must put the upshift light on all the clusters, probably to save cost. Not sure how they got the WTS symbol on the front of the cluster. I did find a cluster on e bay that has the GP and upshift light on it. And it has 95’ C/K stamped on the back. I hope it has the WTS symbol on it. I tried to go online to see if I could information on all the clusters part numbers and what all the revision numbers 3 thru 11 mean.
I bet that's exactly what they did. I looked closer at your photos and it looks like the trace you repaired is a ground that goes between the left turn indicator and the indicator next to it. then the red line you drew would have passed that same ground to the WTS light (one with solder on the pad). something is telling me that that cluster is not the original. an automatic will not have provisions for the upshift indicator. iirc mine does not have an upshift. I believe the PO also might have moved the pin in the connector as well so it would use the upshift indicator for the WTS.
Yea buddy that’s what I thought too, yea they also may have changed the the front black screen to get the WTS light symbol on there. My cluster has 16176841 stamped on the ribbon see pic you can also see the “Glow Plug” and “Upshift” stamps also if you zoom in. All the clusters I see on eBay have that 16176841stamped on them even when the part number in the descriptions are different. I’ve also seen one w/ no GP stamp, just blank and with the “Upshift” stamp w/ the 16176841 stamped on the back. I believe that xxxxxx41 is part number for a generic trace ribbon and not a part number for the whole cluster. Also all of the xxxxxx41 stamped clusters I’ve seen do have different “C/K Truck Tach” stamp on them for various years. Mine is marked 95’. Sorry for the picture quality, my photos are pretty clear before I post them. Zoom in. I wonder if your clusters trace ribbon has the xxxxxx41 stamped in it or the xxxxxx45 number, the proper configuration for our 95’ trucks. Does your 95’ truck have the “ Glow Plug” symbol on the top row or the square “Wait to Start” symbol? Look at my previous pic in my other post. Mine has the “Wait to Start” symbol down on the lower left. Zoom in. Yes I agree that someone’s been in there because my owners manual says I only have a “Glow Plug” light. I still have to figure out why now my WTS light is cycling properly. I might of messed the trace ribbon trying to repair it, I’m my worst enemy🤯. I do have a cluster in my eBay cart w/ xxxxxx41 and 95’ Truck stamped on it w/both the GP and Upshift stamped into it. If it doesn’t have the WTS symbol on the front I’ll have to transfer my clusters front screen to it.
I think part of what you're running into with finding the right diesel cluster is the '95 being the bastard year for these trucks. '95 was the last year of OBD-1 but the first year the GMT400 having the updated interior. I've always wondered how a 96+ cluster would play nice if at all with a '95. Not sure how accurate the part numbers would be for the '95 and everything that comes after, online listings are always suspect at best with accuracy
I just went and looked at my parts cluster I have. also looked on flea bay at diesel clusters. seems they are the same all the way up to 99. the cluster I have is for a gasser, but looking online, the printed ribbon circuits are the same. your welcome to mine for parts, I scavenged the oil pressure gauge and the inner separator that sections off each indicator bulb. here's a decent looking diesel one on the bay..
Yes I agree why so complicated? Why not leave the “Glow Plug” marking off for the trucks that don’t have them. Also never saw any “Wait To Start” markings. Very confusing.
Thanks d, I believe that’s part number ending in 45 isn’t the right one. Glaguator on the Diesel Place got me the right number. Ordered one on eBay. Thank you for the offer. When I get this GP light working it might help me troubleshoot my other problem of intermittent cut out. Yea I have two threads started. Boy sure is a lot of work getting these trucks working properly again😎
Hi everybody, I haven’t posted lately. Still have to do troubleshooting on my new optimizer build. I did get the instrument cluster in and then I tore some ligaments in my foot Mountian biking. That sidelined me for a while. When do get back on my feet I’ll install my new Raptor LP and upgraded battery cables and continue on troubleshooting my intermittent engine stuttering. Then I’ll probably be back asking for more input. You guys have a nice day.
Good to see You posting again and for the update on the happenings.
Sometimes if I got not much going on I’ll report on the weather or throw out some kind of nonsense in the whats happening thread.
Keep us posted on the busted ligeeeyments.
