- Staff
- #21
I bought the kit from Tony Burkhardt a while ago, and I was very satisfied with the machined pieces, and the fit. Very professionally designed. I have not seen the kit from Alligator.
My My... they seem to have a number of tempting products...Some of the kits.
allseasondieselperformance.com/index.php?main_page=index&cPath=64
Very simple install. Remove the factory plastic housing, and then plug the hole up in the resonator. Then install the fittings in the factory spot. From there, just hook up the hose, 1 for each side, and they vent into the air. The hoses get wire tied to the chassis.
Yes, it should be. But when the tubes are not machined correctly and you have an interference fit and the o ring groove in the tubes are so small all of the compressed o ring will not fit in the groove it tends to complicate things.
