buddy
Active Member
Also going to mode the system so the LP will run along with the GP's...
Very good idea. Luckily, if youre good with wires there is a handy wire diagram to do such a mod.
If my current understanding is correct...(big question mark lol) on my 1995 the only time the LP relay is used / energized is during cranking...correct?
Just a suggestion. Poking around the other day discovered a couple of the clamps on the fuel lines weeping. One at the LP was dripping and must have just started cause the truck has been "driveway trained" (not piddling anything) pretty well of late. The other at the T-Valve is wet at the clamp which is the factory style ones so infamous. I'll pick up a hose clamp tomorrow and have done with that one as I used the last small clamp at the LP.
