Injectors, GP's today, ATT and crossover tomorrow....
Tanman, the return line hose is 1/8" inside dia. Napa has the hose also. I don't recall the part number, but ask for return line hose and ask to see the page describing it in their book. It will list "diesel fuel return line". I bought 3 ft in there for like $2 p/ft.
If you don't buy the return line "kit" and buy hose by the foot ask the sales folks about the end caps for fuel return lines. If you have an injection repair shop, or tractor repair, diesel repair, they'll have the two end caps you need, and those are usually use the clamps you hear about so much. If you do any business there they'll probably give you the caps and clamps.
If you can not locate the caps in your area you can take a one inch piece of the same hose and insert a short(cut it off if you have to) bolt, screw, welding rod end.....something to plug the end. That's all the cap is!
When you slide the hose on the injector nipple, lube the end of the hose with a squirt of oil, wd 40, or anything to make it easier to slide on.
Great tips. Thx.
