buddy
Active Member
Rodd, your numbers were normal, you mistakingly said 88.5 when it was actually -0.88 TDCO.  And the timing you see is not base timing when running.  The PCM advances the timing when operating the engine.   Base timing is what is seen at time set, and thats what the 3.5 degrees is referring to.
12 degrees is normal PCM advance when warming up and it should slowly come back to 8-9 degrees.
