540s10
Put a scan tool on my truck today figured I would take a look and see what the timing was since I had it and found something strange... here are my results
Using autoenginuity-
water temp 185*
Desired Timing 12.1*
Actual Timing 12.1*
TDCO 2.46
I entered the time set mode and actual timing read 3.3/3.4
yes it it triggered the SES light
codes p0216 and p1214
cleared the codes and did a TDCO learn (KOKO just to make sure it worked) but there was no change to the offset
any ideas what could cause this? From all my reading I've concluded that when the actual timing is at 3.5 I should have an offset of -.25 -.75 .
the truck runs well before it gets up to temp (bad injectors considering) but stumbles once it reaches the Magic operating temp number where it sets the codes into the ecm.
water temp 185*
Actual Timing 12.1*
TDCO 2.46
