ak diesel driver
6.5 driver
the ones I heard about were IDI
AK makes a good point.
Pulse width on the ds4 is determined by the PCM and actuated through the fuel solenoid.
Timing may be slightly advanced, but I have no idea if the amount of advance due to lower pressures would be of any practical significance.
I change these things through a PCM reflash...
In testing at this point- GM marine nozzels with 3200psi pop pressure.
So far- A much better sounding engine, lower boost pressure, and definitely more power. I used to cruise at 5 - 6 psi boost. Now, I'm cruising at 3 & 4 psi. I used to see 10 and up to 11 psi at wide open throttle. Now it barely makes 8.
Also VERY clean.
Did I mention how "mean" this engine sounds? !!! Has a distinct aggressive engine sound!
I put 100 miles a day on, so we will see how this works... unless the engine decides to take early retirement.
I'm not knocking it but with the same fuel delivery and less boost, it sounds like maybe there is less exhaust drive pressure. IE:less power?
I'm just thinking this out.
Update- So far I am getting around 17mpg with ALOT of wide open throttle runs. Cruising is around 20mpg.
So far I am PLEASED with the way it runs. I definitely have more power.
Just so we are clear, this is the marine GM nozzel, set at 3200psi, DB2, and running strait WMO.
Waste Motor Oil???
Just wondering if you've checked performance towing or not...
Sorry guys. WMO= waste motor oil. Yes, it's 100%.
Yikes! Did you centrifuge it ?
I used to run waste motor oil also. I didn't like the carbon it put on the injector tips,and also inside the precup. Looks like tan concrete,and just as hard. I also seized a few pumps from it,one was a .370 plunger,and will probably never find one again.
Just a quick question here, do you think you'd do any better with regular ole #2? And a hx35 or hx40 turbo? Or the electronic ip? Ok, guess that was a quick 3, but whos counting...
