Randy Curran
So I got the dually running(sorta) but two of the injectors are dripping fuel. There working(I'm guessing), is there an o-ring to replace? And what tool do I need to remove them.
Thanks!!!!
Thanks!!!!
No o-rings in the injectors and the lines. all machined finish fit. You could try loosening the injector line and tightening the top to the bottom. If I remember correctly the top takes a 22mm open end wrench.So I got the dually running(sorta) but two of the injectors are dripping fuel. There working(I'm guessing), is there an o-ring to replace? And what tool do I need to remove them.
Thanks!!!!
Sure it's not a return line ?
