NVW
It can run smoother at a more retarded injection and combustion which is what happens when it pops early or doesnt atomize correctly. The less advanced the less force against the piston.
As far as the minimized risk, there is less noticeable issues when you dont stress the truck, however the main concern of pitting the pistons and scratching the cylinder walls still exists. Thats because if it dribbles when off or just doesnt combust and get pushed out or dribbles just a little after shutdown the fuel will clean the lubrication off the cylinder walls. This could lead to more blowby I suppose as a notibeable indication it has been happening.
Dont worry about overworking the IP, thats a myth. The IP is capable of pushing 4000psi at idle rpm if it had to. So popping off at 2200psi is nothing it would stress over. Additionally at higher RPM line pressure it squirts fuel at 10,000psi, so again 2200psi pop isnt hurting it. What I meant by the IP is working easier is you dont hear as much ticking/clatter from it popping as high. If you arent in the pursuit of power and dont use the truck for power then a low pop pressure could make it run quietter/smoother. Too low of pop might be how injectors are getting burned/scarred when we use these high fuel output PCMs and injection has to work against the pressure of the cylinder compression at high boost.
Definately something that should be common preventitive maintenance. IMO, 100,000 maybe if only a daily driver, 50,000 if you tow often or have performance PCM and have a heavy foot a lot.
Doesn't make sense to me
I think you mean there is less diesel clatter, that can be but bad injectors are injecting at different times so there is an uneven idle.
