hookedup50
The other day while driving home from Boston I heard a different noise coming from the engine bay. I got up the next day and the truck would not start. It needed a starter and is unrelated. At idle, there is no audible difference. Between 900 and 1kRPm there is a clatter and it goes away shortly after. At highway speed with no load and just enough throttle to maintain speed the clatter is back. At speed there is an occasional pop. This noise is coming from the drivers side bank. If this were a rocker retainer button/ball, the noise would be adible through the whole rpm range. This happens in park as well as drive. It is not something loose rattling, I'm not that lucky. When I have time I will throw the carcode on it and try to figure out how to turn off injectors. I've read about another way to manually turn off an injector. If that turns up nothing I will pull the valve cover. There is no DTC light on and only slight loss of power if any. I didn't push it though, cause I limped it home. There is no ai in the return line. Thanks in advance.
