GTOJohn
I am very new to diesel engines and just recently picked up a non-running '95 K2500 6.5 Turbo Diesel 4x4 extended cab that I would like to use for towing. The body has 333K miles on it and supposedly the engine has 70K miles. The diagnosis from the seller was that the "fuel pump" wasn't working and there was voltage at the pump, but no pressure at the fuel manager. So I replaced the lift pump and found no fuel at the fuel injectors.
My buddy told me that it is time to replace the injection pump, but I would like to troubleshoot this further. I read a lot here tonight and learned a lot. It is a fantastic forum and you guys obviously know a lot about these engines. Will you please tell me what I need to do to make sure that I don't have a PMD problem, fuse, wire, pump, etc?
Problem: Explain your problem in concise language (ie: Cranks but won’t fire). ___Cranks but won’t fire. New Lift Pump, fuel present at fuel manager, but not at injector._________________________
- Year: __1995____
- Truck model and class (ie: c2500) _K2500________
- Automatic or Standard ___Standard_______
- Mileage: (indicate miles or km) __333K_______
- Replaced parts and mods (IP, PMD, chip/PCM, TM, injectors etc) _____?______
- Model: ‘S’ or ‘F’ engine, NA or Turbo, EGR? ___Turbo___________
- Ambient outside temp: (indicate *C or *F) ____80*F______
- What fuel are you using? (#1 Diesel, #2 Diesel, Bio, VO, WVO, etc) ____?_____
- What fuel additives are you using? _____None______
- Where are you located? ____Lebanon, OH_________
- Air filter ____?_____
- Fuel filter ___0 miles ago______
- CDR Valve? ____?_____
- Coolant – last flushed/replaced at _____?________
- Oil – synthetic/regular, changed at _____?______
- Batteries – state of charge, (matched set) replaced at ___New__________
- Battery cables and grounds (removed, cleaned and tightened): _____Ok_________
- Glow Plugs - how many miles on them? ____?_____ What type? _____?________
- Injectors - last changed at _____?__________
- Describe any related factors that might be part of the problem. _____Lift Pump just replcaed_________
- Have you checked for DTC (Diagnostic Trouble Codes)? (Y.N) __Y__ And? __None stored______
Diagnostics:
1] Starting:
1a] Does the engine start? ___No______
1b] Does the engine crank over? __Yes______
1c] Are your batteries fully charged? ___Yes______
1d] Have you removed, cleaned, and tightened all battery connections? ___Yes_____
1e] Does your Wait to Start light come on for a time? How long? __Yes, about 10 seconds or less_______
1f] Does your glow plug light come on? ____?_____ For how long? ____?_____
1g] Do you see smoke from the exhaust while cranking? What color? __No______
1h] Does the Service Engine Light Glow during Start/bulb check? ___Yes_____
2a] Can you hear your lift pump working? _____Yes_______
2b] Do you get a steady flow of fuel from the water drain (T-handle) ? ___Yes______
2c] Loosen the inlet line from the IP – is fuel coming out (Lift Pump on)? ___________
2d] Loosen an injector line and crank the engine - does fuel come out? ____No_____
2e] Do you hear a vacuum (hiss) when you remove the fuel cap? ____Yes_______
3] PMD / IP Issues
3a] Location of PMD (on pump, on intake, remote mounted) __on pump_________
3b] Condition of Extension harness (if used) Vendor or Homemade? __looks stock_______
3c] Condition of grounds / ground wires to IP / PMD. Check Harness. ____?_____
3d] PMD Make: _____?______
3e] PMD Age: _____?________
(Nothing that I can think of)
Thanks,
John
- Year: __1995____
Diagnostics:
1] Starting:
3] PMD / IP Issues
Thanks,
John
