Mudbath
Old Smoky
There is more ways to skin that cat without removing the timing cover..
Pull the # 1 injector,use a rod or wire in the hole and run the piston up to TDC,see if the IP gear marks line up at 6 and 12 ,if not,turn the crank another revolution.
Tried that but pre cup in the way of piston and could not get rod through. Will have to pull things apart. With other reference it does appear to be out at least a tooth.
