Mudbath
Old Smoky
I have a snapshot attached and what is bugging me is where it says Actual injection pump timing I rotated the pump quite a bit to passenger side and got it down to the 28.95 Deg* (was at 35 Deg * and looking at old snapshots, has alway been high). Is this the same number that is shown in Time Set as base timing which I believe should be 3.5 Deg * or as someone else said 3.8 Deg * which will get you to a -1.50 to -1.85 range of TDC offset (when setting TDC offset)
This truck has always had a cold starting problem and everything has been done to it including just replacing the Injection Pump to a DS4 5521S. Also engine will stall when doing Time Set to TDC Offset in GMTDScan Tech. So finding the base timing there is impossible for me to do. Is it possible that the Injection Pump gear timing has always been out? PO had the IP changed out on warrantee years ago. When I changed pump I did it through the oil filler tube hole and left the gear the same. Cannot see where the gear timing is from there though, will have to pull the front of engine to see for sure.
View attachment GMTDSCan Tech.pdf
