buddy
Active Member
Some guys in the other thread were saying there IPTC was growing rapidly but they didnt have any timing DTCs or issues from desired to measured. I dont know if you can trust that one from Carcode.
I doubt there is anything wrong with the OS. Just make sure its connector is seated good. You never know what PO did. If you can get eyes on the crank sensor on timing cover see if it is the type with a solid plastic casing with mounitng tab. Or is it the type with a metal mounting tab that is capable of popping off and being put back on in the wrong orientation. If its the all solid plastic I wouldnt suspect it either.
