new2diesel08
I was recently tuning up my trucks ( cleaning the air filter, new fuel filter, changing the oil sort of stuff ). I had some extra time on my hands and desided to block off the EGR.
After I did it I noticed a loss of power. The truck does not sound as throaty when I hit the pedal either.
I noticed the baro Sensor is connected to the same solinoid that the EGR was connected. I know ( or think ) the Baro measures manifold pressure and tells the computer to ad fuel.
How I did the EGR delete was just a simple plate under the egr and bolted the EGR back on top of it. I plugged the Vacuum line off.
Is this right?
Do I Need to some how connect the Baro back to the manifold so it can operate correctly?
My truck has a GL4 chip from Heath and no codes are being thrown.
Do I have to reset the computer to let it go through a relearn?
I was going to pull the manifold off today to install the J code gaskets that block the egr tunnel to eliminate the heat. But now I am thinking it ran stronger with the EGR hooked up.
I know something is weird here. Please help.
Is this right?
