Hey all. It's been a bit of a while. My last time on here before tonight and this thread was back in March. At the time I owned a 1999 2 door Tahoe 6.5 & a 1995 6.5 Suburban 1500. Maybe some of you remember my trucks. Maybe not.
Well, the 99 2 door I bought first. Then wanted a bigger vehicle so I bought the 95 6.5 Suburban. I was happy with the Suburban so I sold the 99 Tahoe. After signing the title over to the guy who bought my Tahoe the guy was checking out my Suburban. After getting under it he told me man... This truck isn't safe to drive... Your frame is cracked. Well.. The used car lot bought it back.
That was back in March. Since then I have taken my time and searched the Internet for another 6.5 Suburban. I couldn't find anything that I felt was worth investing my money and time into until 8-03-2016. I found a 1999 Chevy Suburban LT 2500 4x4. The very next day on 8-04-2016 I bought the truck and drove it home.
I looked up some RPO codes & She's got 3.73 gears in the rear and a 10.5 rear axle. Oh yeah She's got 197,000 miles.
PO stated he did the following...
So far she has PMD relocated to front grill, mechanical waste gate tensioner, vacuum pump delete, bully dog economy mode MPG tune, leveling torsion keys with shock extenders, 3.5 down pipe & 4 inch straight pipe no muffler to a 10 inch tip.
Here's what I want to do. I plan on looking for the parts I will need and I'm going to start ordering them this week.
I know how important the grounds are on the 6.5 so I want to buy a good Ground kit.
I want to do a Oil & filter change.
Air filter check.
Fuel pump replace & filter & check fuel lines... Possibly put SS braided fuel lines
& a fuel pressure reader or meter.
Replace my oil cooler lines with SS braided lines
Check my brakes and condition of my brake lines possibly put SS braided lines.
IP... Injection Pump... I'm lost here...
Water pump.... Lost here too....
Pillar pod with pyro meter, water meter, boost and oil temp.
Intercooler with bigger freer flowing intake.
Better turbo... Thinking hx40ll or even hx35 or ATT. I can get a new hx35 cheaper! Cheaper isn't always better so need help here. What's the differences? From what I've read ATT is a direct bolt in and then I shouldn't need a intercooler even if towing. I need help here especially.
Change headlight housings to clear glass.
Fix my AC.
This will be my first diesel I've even worked on. My other two I only owned for a short period of time and didn't do anything to them. Any input and or advice will be appreciated and a well deserved thank you to all in advance... "Thank you"
Air filter check.
Fix my AC.
