Ignition switch harness plug
Tovar
Arizona
image.jpeg image.jpeg Switching out my ignition switch harness. Been stymied by a little white plug that is located on top of the tumbler area. It is not of the norm. I do not see how to remove it, and would rather seek advice than to break it and cause more issues. Since it is part of the harness, it has to be removed.
To remove the little white plug, take a small flat head screwdriver, and insert it between the plug and the casing, in the middle, on the upright side (not where the plug rests on the casing). Gently, turn the screwdriver clockwise, an push the terminal side (where the wires are) towards the passenger side of the truck. The plug will swing out and release itself. Plug tells the truck the key is in the ignition.
