My 97 needs a belt, went to put slack in the idler/tensionor and the bolt spins, and it wont stay tight. Do I need a new idler or is there a fix for this?
Isn't there a 1/2 female square made into the idler arm somewhere to loosen tension???? I remember using a std 1/2 ratchet might have used a short pipe for cheater just to make it easy. Seems like that is what I remember last time.
I have a brand new gates 38118, should be same one for your truck. mine went out in new mexico and had to buy one there. If you want it let me know. don't know if you can wait.
mine has it but it is a 3/8 not 1/2 inch. and it makes it easy when you put a ratchet in there. EdIsn't there a 1/2 female square made into the idler arm somewhere to loosen tension???? I remember using a std 1/2 ratchet might have used a short pipe for cheater just to make it easy. Seems like that is what I remember last time.
Not a great pic, but if yours is the same, undo the nut on the plastic
tube coming from the turbo, just above the alternator - when it's lifted
up, you can see the hole for the 1/2" ratchet to move the tensioner
