I think my truck just made a bowel movement...
Yep, then you'll get Emissions Test as well.
Just about every truck up in NY has commercial plates. Its based on the weight, not what you're doing with it. I had them on both my trucks and I never got emissions test.
I found the Trick though. The DMV Issues the Plates based on the Weight that's on the Title. If it's UNDER 5500lbs, you can get Passenger Plates. I Looked on my Title, 5490lbs. :thumbsup:
in ny diesel are only safety inspection. and over 8001gvw. gas and under 8000gvw safety and emissions. i should know im certified to do nys inspections. my truck passes every year......... hmmmm
well then...I just might be taking a trip to cassadaga in 10 months.....sad thing is I know exactly where it is.
I thought it was a gallon of diesel for the regen? And the regen took place approx. every tank full?
Maybe not, read that some where. I will probably find out soon enough as I am looking to step up to a new 09 here soon, if I sell my truck....
well......with the dpf and the edge evolution my truck went into regen 4 times between syracuse, ny and washington, dc with an empty trailer....and 7 times on the way back with a loaded trailer...fuel millage tanks during regen....I haven't run a full tank through the truck since the dpf delete...but so far the results are promising
why is it so sad that you actuall know where the little cow town of cassadaga is? just kidding it does suck here only one good bar in town
